A friend did the same thing on his bike. So, I got Marvel's mystery oil, put it in the spark plug hole, and let it sit over night.
Next day, I let out the clutch, and went BACKWARDS with it. It freed right up. If you do that, make sure you inspect the cylinder, and piston. You can go to many of the websites on here, and get replacement parts. It doesn't matter how bad it is, you can get almost everything you need. I mean the cylinder head, the piston, rings and cylinder itself. Replace all of those (if necessary) and you should be good.
Either way, weather you get lucky or not, you can fix it for less then 50$$ (unless you messed it up very bad)
