when you install the throttle into the slider barrel , should the needle clip be above or below the c - shaped washer? I have run both ways and seems to do fine either way but just looking for a census!
How could it work either way??? The needle could "float" up if not in this order:when you install the throttle into the slider barrel , should the needle clip be above or below the c - shaped washer? I have run both ways and seems to do fine either way but just looking for a census!
So you chuck the needle up.....how much do you remove?I have found that when I get an optimal full throttle mixture, the bottom end is too rich. Good off idle and mid? too lean at WOT.
I taper my needles to fix that. Not for the faint of heart.....
