Need a clutch for hs 49cc 4 stroke
Greenbiker
83
Oklahoma
Have new motor with about 100 miles on it. Broke a clutch spring and replaced it hastily. Broke another spring on second ride. Recalled that while changing spring there was lots lots lots of black dust. Upon looking at pictures of clutches i realized that the pads are worn away! Seems prettt quick so i think i need to bring the idle down a scosh. But im going tp change the clutch fly weights out and was womdering if the tapered shaft clutchs for the mini bikes sold on amazon would work mine is a 78 mm clutch and they look nearly identical and wanted to go that route if i could. Anyone know? Thanks.
curtisfox
6,082
4,060
minesota
Don't think you can put a taper shaft clutch on straight shaft engine. Have you looked on staton-inc ...............Curt
Venice Motor Bikes
Mar 20, 2008
7,342
2,010
Los Angeles, CA.
A good way to make the clutch last longer is to always pedal the bike when your taking off from a stop...
Just giving it gas like a mini bike (without pedaling) is real hard on the clutch! :(
curtisfox
6,082
4,060
minesota
YES! And also get the ideal down like he said. Not only that but if his gear ratio is to high it will burn them out in no time............Curt
