C Cutlassjim New Member Jan 19, 2016 #1 I just found this on CL this morning. The fuel system needs to be cleaned out. It does have some surface rust on it. Only 49 miles on it. Anything I need to know about this carb? Any insight is appreciated. Attachments 00H0H_iSUNaWPjUG1_600x450.jpg 55.4 KB · Views: 394
racie35 Active Member Jan 19, 2016 #2 I would drain it( there's a screw on it I believe). Maybe run some carb clean through it...check the fuel and give it go.
D dmb Active Member Jan 22, 2016 #3 if it wont idle the pilot jet is clogged, happens all the time. best to replace it, try carb cleaner but a pretty small hole
