Bill,
That would explain it. Have you heard anything about the newer kits coming with 2 spacers that apparently came with this man's kit? I'm wondering if this is the way they intended the engine to mount if they have indeed increased the diameter of the front mount to accommodate oversized cruiser frames. In view of the fact that he has the engine mounted, apparently solidly, I'm of the opinion that a slight misalignment may not be enough to be concerned with. Even if the motor leans a little, as long as his chain isn't hitting the clutch actuator cover and is reasonably aligned to the rear sprocket, I'll conclude that maybe he's good to go. Any other opinions?
