My 1st build - CB2 inspired rack mounted, scissor lift, FD
I'm going to bed early, been feeling poorly all day and apparently I have a 101* fever.
I really appreciate the info you've shared. I'm looking forward to showing you what I come up with.
Goodnight everyone.
Some photos of CB2's bolt together mount that intend to pattern mine after.
That was a pretty awesome bike!
I did some number crunching with a calculator and came up with this. The # of inches in a mile is
63300. This is equivalent to 60mph if traveled in an hour. Divide this by 60 and you get the inches for 1mph(1056). Multiply this by a given mph, say 18 and you get the inches of roller needed for that speed/distance(19008). Multiply your roller by 3.14 then divide that into the mph/in figure. 2in roller has a circumference of 6.28in. 19008 divided by 6.28=3026. You will have to turn a 2" roller 3026 rpms to go 18mph. I think.
To make sort of quick replaceable rollers, run a 5/8 jackshaft. You can simply remove the off side drive bearings lock collar pull the shaft over a bit and drop the roller out. The roller can be held in place by two lock collars(set screw type). Drill the shaft slightly to make a deep dimple for the collar sets to bottom in. That makes a positive lock on the shaft. Cross drill and tap one collar to 1/4-20 and make a drive pin that threads into the collar from a bolt. Just drill corresponding holes in the rollers then lock in place with the collar. You will be hindered a bit by having a chain to contend with as it will have to be removed to slide the shaft.
I had a spring loaded idler for the belt that tolerated moving the shaft with the belt in place.
However a chain will run with a well designed spring idler also. Simply stack a couple of
sealed bearings to make the wheel and leave enough chain on the non drive side run to just be able to lift the chain off.
The beauty of the direct drive bikes is a roller change could be made in a minute or less.
OK, I find the chart initially confusing. I read it wrong. My math is correct
The easiest way to calc the rpm of a roller is to use the magic# 1056.
Multiply this times the mph desired then divide by the circumference of the roller.
I will do the 17.8@3000 rpm on the chart.
1056x17.8=187968. 187968 divided by 6.28(2"roller)=2993rpm. Im guessing they rounded
the value.
Conversely to figure mph multiply the circumference by the rpm then divide by the magic# 1056.
3000x6.28=18840 18840 divided by 1056=17.84
Now one can easily figure roller performance. It is unique among all drive ratio/speed
calculations.
the value.
calculations.
Thank you CB, that is very helpful information.
I have another question. You said, "I had a spring loaded idler for the belt that tolerated moving the shaft with the belt in place. However a chain will run with a well designed spring idler also. Simply stack a couple of sealed bearings to make the wheel and leave enough chain on the non drive side run to just be able to lift the chain off."
I've seen photos of your spring loaded idler but I'm having trouble visualizing how the stacked bearings you describe will support a chain.
The bearings are stacked together side by side then thru bolted to a spring loaded arm of course. Chain runs very happily on the smooth bearing shells. Or you can run
the common MB kit idler wheel. A smooth idler wheel
allows for chain run out and is less critical than running
a tooth idler.
Heres a pic of two flange bearings back to back making a belt idler(works on chain too)
on my Maytag 3speed FD. A very complicated build!
005-jpg.77367
I've read that build too. What a cool looking motor! I'll read it again to see if there are any top down photos of the idler. If not, do you still have it? A close up would be helpful.
I still have the old girl. Will probably die with it. Too cool to get rid of. People come out of the wood work to look at it when I ride it.
Here a current pic sorry about the quality but you get the idea, old camera hates indoor shots!
I was wondering what the engine setup is like and mounting. You have pictures? That roller for a moment looked like one of the pie electric motors. It grabs well on the wheel I guess.
Thank you for the photo. I just spent 10 minutes reviewing all 15 pages of that build to download 5 or 6 helpful photos.
No FD inputs that I saw. Great for chain\sprocket calcs.
Noted. I was looking for simple way to calculate how input rpm and output rpm change when plugging in a variety of sprocket sizes. I think it will make it easier when I'm figuring out my drive ratio.
This is what I came up with. Revisions due to math mistakes or an error in my logic are certainly possible. My biggest assumption is that my 3 1/2" hole saw will make a 3 1/4" roller. I'll do a test cut tomorrow.
Goals
30 mph @ 4800 rpm
Good hill climbing ability
Known Factors
My clutch has a 10 Tooth Sprocket
I own a 3.5" hole saw (3.25" roller?)
Calculated Factors
3.25" roller needs to spin at 3102 rpm to go 30 mph
10T to 15T sprocket will spin the roller at 3200 rpm
10T to 16T sprocket will spin the roller at 3000 rpm
4" roller with a 15T sprocket = 38 mph
4" roller with a 16T sprocket = 35.7 mph
2" roller with a 15T sprocket = 19 mph
2" roller with a 16T sprocket = 17.9 mph
Writing from memory(may be questionable) as I recall the Red Schwinn bike ultimately
ran a roller direct some where in the 3.5"+ range around 4500rpm. The bike topped around 45 mph, easily out running my friends smaller engined vintage Vespa, much to his dismay.
Thing was I had to pedal pretty fast before dumping the "clutch". The engine lugged a bit up to
around 15-18 mph then began to take off.
The Mongoose ran governed which was cool. It was a great form of cruise control. I used a friction lock thumb throttle and it was a set and forget. It handled the cruise speed and poured it to it on the hills. This worked well only because this bike cruised the back country. It cruised around 25 mph @3600 with a 2.3 roller(cut with a 2,5" saw), and climbed fairly well. If I was really in hill country I swapped to a roller closer to 2".
I only said the above to give an idea of extremes that can be done with roller sizes.
Your target speed/gearing sounds feasible. 30 mph is a nice speed, will keep up with a lot
of urban traffic(in my town anyway). 20-25 is a nice cruise. It would be nicer if the engine rpms
are in the mid 3k range.
Go for it and see how it works out. May take a roller adjustment one way or the other. If you get serious about FDs with wood rollers you will soon have quite an assortment of hole saws!
