Fizzbane
I have read and seen a few people on here using the 5.8hp and the 9.4hp Morini motors with jackshafts. It seems like all of you are using internal shifters like nuvinci or a nexus. Some have blown up these internal shifters.
I am curious as to why no one has used the conventional cassette setups? What is the failing point?(if any)
Is it the derailer? cassette? freewheel hub?
If it was derailer or cassette that would fail, would the bike work fine with a standard freewheeling hub and a single sprocket?
If the freewheel hub was the main fault, you could not have a cassette meaning no derailer, but you could get a single speed sprocket that is non-freewheel. Keeping in mind that the cranks have a freewheel on the front sprockets, would this setup work? Is there something horribly wrong with this idea?
I am asking anyone who has experience with the sort of power these motors have and understand the stresses that will potentially arise in certain areas.
One reason I have for asking is because gearing would be CHEAPER! Single sprockets for bicycles are cheaper than MB ones and just as or more accessible.
Another reason is the build I am going with is on a GT-LTS. It has an intricate rear shock system with odd pivot points making a device to take up chain slack more difficult. (see EZ's summer build) He made his a hardtail because of it. With a jackshaft it should be easier to get a tensioner that hangs off the derailer hanger to pick up the slack like it would normally.
I have been thinking about these things for a while and thought I should ask some people with experience, who may have never thought about it before.
Ill be starting a thread on my build as soon as it really gets moving along to document the process.
Thanks for reading!
--Fizz
Thanks for reading!
--Fizz
