I recently found another weak spot in the Monark springer.
I'm 200 lbs and have around 2500 mi on my bike and springer.
The issue i had is the head nut striped from all the repeated force of the springer going up and down. luckly I had my neck all the way down and tightened all the way or the front forks would have come apart on me.
I recommend once you get them set up properly you drill and put aset screw threw the head nut and fork then dremil the extra out of the center so the neck can fit back in . This should eliminate the problem.
