cumminsbayou
i have a 49c 2 stroke motor, it has no sprocket so i ordered a 39 tooth for it. Is this to steep of a sprocket for the stock motor on a 26in bike?
I'd be more apt to go with a 44t on the small 2-stroke. I used to run 44t on my 66cc 2-strokes and found it to be a good overall gearing set-up. I could climb steep hills with ease and still go plenty fast on the flats. Didn't need to pedal on take-offs either. Just my opinion.
ok that is what i thought about it. How fast do you think it will go? i got the kit used from a guy in south florida for 45 dollars all i needed was the sprocketNo. You're right in the ball park for a good all-round sprocket size for most types of riding. If you have steep hills to climb or you weigh a lot you might find you'll be doing a little pedal assisting but for flat ground you'll be good.
A 40 to 44T sprocket is a good range unless you're looking for maximum top speed or climbing steep hills a good part of the time. Think of your bike as a car with one gear. Your 39T puts you in something like second gear of a car where a larger rear sprocket, 44 to 48T is more like first gear and a smaller sprocket, 36, 32, even 28T is like being in high gear, 3rd or 4th.
You should be good with 39T
Just curious, what kit did you get that came without a sprocket?
As long as the carburetor is tuned right and the engine isn't worn out, you should easily see the high 20s, possibly 30.ok that is what i thought about it. How fast do you think it will go? i got the kit used from a guy in south florida for 45 dollars all i needed was the sprocket
