greaser_monkey_87
I wanted to share some notes on tuning the MaxTorque "SS" six shoe clutch. This clutch was given to me for free, so I'm investing time and a little bit of money to make it engage as smoothly as possible. I read up on clutch tuning about a year ago, but haven't had enough money to buy all the necessary parts to tune this clutch. Before I get too deep into this, let me add that at this point I've already got the clutch engaging pretty smoothly, and I'll share what I've done so far to make it run smoother. The rest of the mods I'll be performing are just to make it engage better at lower rpm's, because it does slip a little when going very slow or giving it short bursts of throttle, such as when I need to stop and speed up quickly.
So the first mod that I made was to change the spring. The stock spring is silver and engages at about 2200 rpms with the stock shoes. There is a green spring that will engage around 2500 rpms with the stock shoes for those who may be interested in trying it. I did not use the green spring. I used the black spring, which engages at 3100 rpm's with the stock shoes. Changing the spring helped a good bit at first, but eventually the clutch began to chatter again badly.
Next, I began to notice quite a bit of play in the drum. Upon disassembling the clutch to clean and inspect it, I noticed that there is a sizable gap between the clutch shaft and the bushing. There was a thin fiber washer between the two, but it was not thick enough to take up the entire space. I went to Home Depot and got a thick fiber washer. I cannot remember the thickness, but it was the only fiber washer they had that was the same inner diameter as the fiber washer that had been in the clutch to begin with. I took the original washer with me to match up the diameter. The thicker fiber washer cost about 60 cents. It takes up the entire space between the clutch shaft and the bushing. Eliminating the play in the drum helped the clutch to balance itself better when engaging.
The next modification I made was to replace the bushing. This is not a mandatory step for tuning, especially if the clutch is new. The replacement bushing is exactly the same as the original bushing. I replaced mine because they do get worn down after awhile, and I'd been using the clutch for about a year. I've no idea what kind of use it went through before I got it. The bushing was 3.50 plus 7 flat rate shipping. Upon replacing the bushing, I began to lubricate the clutch with grease. Motor oil is generally recommended, but it slings all over the place and can get inside the drum, which is bad. I disassemble the clutch and use a q-tip to grease the inside of the bushing, and I also grease the clutch shaft at the same time. This has had a huge effect on the smoothness of engagement. I take it apart once a week or every two weeks depending on how much I ride. I also grease the crankshaft to make it easier to get the clutch on and off. It used to get stuck so bad I'd need a hammer and something to pry it off with. Now it slides right off.
I have also ordered heavier shoes for my clutch. A lot of people will not agree with this, but during my research on clutch tuning, I read that the best way to get smooth engagement across the powerband is with a heavy spring and heavy shoes. It doesn't make sense to a lot of people, because it goes against popular theory. So I expect I will get some negatory comments here about it. But the shoes have already been ordered. The stock shoes weigh 46 grams. The wedge shoes, as they are called, weigh 62 grams each. Lighter shoes provide a later engagement, but they dont lock as quickly even when the clutch starts to engage. Heavy shoes provide an earlier engagement as they fly out and catch quicker. I'm expecting that with the heavy spring and heavy shoes, my clutch should engage a little sooner but lock very quickly. I haven't received the shoes yet, as I just ordered them today. When I install and test them, I will update this thread. Fyi, you can try to order the wedge shoes from affordable go karts if they have them in stock, but I ordered mine from comet kart sales and the shipping was $5 cheaper than agk.
So that's all I have to share for the moment on this.
