max torque clutch
glennbo
does anyone know where i can get a clutch drum for a 5/8 shaft 41 chain max torque clutch. burned up the original and cant seem to find a vender it seems like they all sell the 3/4 or 35chian
thanks glenn
I'm still wondering myself if the trouble I have with getting the centrifugal clutch of mine on the engine crank shaft turned around 180 degrees (the bell on the inside) can be solved short of modifying the crankshaft keyway slot nearest the crankcase cover oil seal.
The key way cut on the engine crankshaft closest to the crankcase cover oil seal is a rounded sloped cut. I have had to modify the key to get it almost fully installed. Its not quite there, just 1.3 mili-meters short of having the end of the engine crankshaft even with the centrifugal clutch pulley.
I have had the people at Max Torque the manufacturer of my centrifugal clutch mention that turning the clutch around is OK to do as the shoes on the one I have are symmetrical and grip either way. I want to have it install like this so I have the belt further away from the engine so I can fit the flat idler pulley I am to get in the mail tomorrow.
I'll be checking with Briggs and Stratton what they know of this too. Any help appreciated!
Art Fish Mobile Motor Bike prior Motor Bike DIY'er build to add side car maybe?
See posts #93 to #95 on page 10 for pics of the problem
http://motorbicycling.com/showthread.php?p=454501#post454501
http://motorbicycling.com/showthread.php?t=29678&page=10
MT
