Hey guys, I finally joined so I can talk to you about the issues I'm having with this motor. Since getting it running again, I have no torque at all. On straights it runs good, but as soon as I hit even the slightest incline at all, it bogs down to nothing. So, I've been going over the motor looking for issues.
One issue I found is that the spinning magnet which should never actually touch the magneto coil is grinding on the bottom leg of the coil, and the top leg has a pretty wide gap where it should be closer. It runs like this, but I can hear a sneak from it rubbing. I grinded down one magneto coil I had to stop the rubbing, but that still leaves huge gaps between the magnet and coil and looks ugly. I have tried different coils and magnets and have determined none of those are out of shape. It is either the holes weren't drilled properly making the coil sit too high and rubbing the magnet, or I'm wondering if the crank is bent. If I am not mistaken the magnet attaches to the crank? I've never taken the crank apart and wouldn't know what to do if this was the problem. Anyone experience anything like this? I can give more details later. Thanks
