Magnecor Plug Wires From SBP!!!
Pablo
Dec 28, 2007
3,682
23
Duvall, WA PNW
www.sickbikeparts.com
New plug wire!!!!
MAGNECOR
Electrosports-70 7mm Ignition Cable
7mm outside diameter
Metallic Inductance EMI Suppressed 1.32mm CN20 chrome-nickel conductor
Black high temperature/high strength EVA jacket bonded to EPDM insulator
EXTREME STRENGTH HIGH TEMPERATURE RESISTANT SILICONE RUBBER JACKET METALLIC
INDUCTANCE SUPPRESSED CONDUCTOR ACHIEVES SUPERIOR EMI SUPPRESSION
WITHOUT A CONDUCTIVE COATING
Construction Type......................... Two section: Insulator bonded with tape to high tear strength, high heat resistant outer jacket.
Insulator Material.......................... High dielectric silicone rubber.
Outer Jacket Material.................. Extreme high tear strength, high temperature resistant silicone rubber.
Heat Resistance........................... 205°C (400° F) service temperature.
Dielectric Strength....................... 45,000 volts.
CONDUCTOR
Conductor Size............................. 1.90 mm in diameter.
Conductor Type............................. Magnecor Metallic Inductance RFI and EMI Suppressed. No conductive coatings applied.
Core................................................. Ferromagnetic base over Kevlar and fiberglass substrate.
Windings........................................ 77 turns per cm (200 turns per inch).
Windings Material........................ Stainless steel.
Resistance..................................... 98.4 ohm per cm, 3K ohm per ft. + 10%.
Capacity.......................................... 45,000 volts, 2kVA.
TERMINALS
Spark Plug..................................... Stainless steel snap-lock 180° bendable and fixed 90° styles.
Distributor and Coil...................... Brass, stainless steel snap-lock 180° and 90° styles.
PROTECTIVE BOOTS
Spark Plug..................................... Silicone 205° C (400° F) - 90° style used
Magnecor 7mm ELECTROSPORTS 70 SS Ignition Lead Specifications
Magnecor’s (Original Equipment size)
7mm Lead Sets now use
Vastly superior replacement for OE and
aftermarket ignition leads (wires in USA)
using carbon conductors or resistor/
connectors at lead ends, all of which reduce
spark energy when deterioration develops
with usage.
ELECTROSPORTS 70 SS IGNITION CABLE, with
its updated high-tech wire-wound conductor,
will properly suppress both RFI and EMI on
all engines without reducing spark current
or deteriorating with use. The high tear
strength silicone rubber insulating jacket
provides better insulation than most 8mm
aftermarket ignition leads, and new
construction provides better terminal
retention than ever before.
Any lead set using ELECTROSPORTS 70 SS
IGNITION CABLE can be used on both older
and newer carbureted engines as well as
the most modern fuel injected engines using
any electronic engine management system.
Suppression is also provided for 2-way radio
and computer equipment.
We decided go top of the line with our plug wires. Rather than discuss forever the trade offs with a solid conductor and a carbon core, we went with the best. Same price as our previous wire, $6.49. Also we have a limited quantity of remaining orange wires, clearing these out at $3.99.
Sick Bike Parts Products
