ferball
I know one of the holy grails that some here are looking for is a cheap reed valve for this high tech, high performance engine....
So I had a thought yesterday, why not use an inline check valve on the intake between the carb and the engine. There are plenty of posts of people lengthening their intake or altering the angle with cheap tubing/hose. So why not add a check valve in the same manner? Has any one tried this? I was thinking that you would need to use a swing type valve as opposed to the spring type, but I also found cheap 1/2 diameter vacuum check valves that would probably work. My concern is that the constant open close would eventually cause the valve to fail, and that would get sucked into the engine, so I was looking for an all plastic valve that would minimize damage in such an event.... Has any one tried this? Can you gear heads tell me why a reed only would work and not a check valve?
