My problem with the stiletto front disc is I want to keep the 48 spoke front wheel with HD 15mm. axle.  No disc brake rotor mount on the hub and when I mount the caliper to the OEM fork mount it does not clear the spokes.  I like the way I plan on gearing it.  10t on motor drives 24t on LH jack shaft.  RH jack shaft has 18t to drive rear derailer.  Freewheel sprocket on jack shaft for pedal chain.  24/18=1.33 multiplier to rear sprocket.  34t(1st gear) becomes 45.22T  24T(2nd gear)=31.9T  14T=18.6T Ultimate overdrive for flat land cruises.  Just wish I had a gear in between 1st and 2nd.  I think front and rear disc brakes are going to be a must.
Don't look at the welds on the exhaust. To hot, to tired, and I ran out of gas!  I will make it pretty later. I like my motor mount.  Very little vibration by being mounted on sway bar end link bushings.  Still more work to do but it is coming along.  Progress not perfection!
micargi puts our good ones and they put out crap too. My stretch builds have suffered from broken frames, but only on the builds I've drilled holes into.. (which I don't anymore as that's about a $200 mistake).. the wheels are crap, the 68 spokes are a beyotch to get the sprocket mounted onto, and you can pretty much forget about that Hi-Stop coaster brake. If you're good with swapping out wheels, then go for it. I use the Falcon GTS regularly for builds, and the china girl engines fit like they were made for that frame. Again, just don't dill the frame and be prepared to buy some double walled rims..
