Lifan 79cc 4 stroke bike engine Clutch Screech
Davideo
171
163
43
84
All of a sudden I have this horrible. screeching noise coming from my bike, I cant even walk it along without experiencing it. All comments and suggestions for a solution are much appreciated.
MotoMagz
1,812
1,117
Michigan
Your chain will natural stretch. So you will have to adjust motor forward or remove a chain link. If a link is to much go with a half link . Also remove clutch to investigate! Is the clutch or jackshaft making the noise?
Davideo
171
163
43
84
Thanks Moto! The chain is rather loose as you say and the bell drum rattles around a lot, not sure if this movement is normal since this is my first experience with 4 stroke engines. I have since isolated the source of the problem to be in the clutch its self. After removing and taking it apart I found lots of grit and some aluminium shavings mixed with grease loose inside the bell drum. After a cleanup and bearing lubrication its operation seems to be back to normal....we shall see.
  • Like
Reactions: FOG
