Leaky carb
Nitro24
7
51
I have a new problem, I have a steady leak out the carb air filter. It only stopped when I turned the fuel off from the tank. How do I fix the leak? Thanks.
allen standley
1,123
235
Bangor, Maine
Float Needle Valve stuck. Next time it leaks try bouncing the bike back tire off ground. If your engine is tilted too far forward this aggravate the issue. Or needs a cleaning. tiniest speck of dirt will cause the needle to not seat. As Active says "Always shut the tank valve off when parked"
