D doublezo New Member May 3, 2009 #1 hi everyone. i finally got my bike to start and run. i noticed that i had a fuel leak and noticed its coming from the tickler. has this happened to anybody else and how should i fix it. thanks.
Dave31 Active Member May 3, 2009 #2 You may need to adjust your float so the fuel level in the bowl is not so high.
D doublezo New Member May 3, 2009 #3 ok ill try that. im new to these motors. do i just need to bend the two metal tabs and if so, which way up or down?
Shadeslay New Member May 3, 2009 #4 http://motorbicycling.com/f30/motorized-bicycle-carburetor-install-rebuild-302.html I believe it's post 9-11 in that thread.
Dave31 Active Member May 3, 2009 #5 doublezo said: ok ill try that. im new to these motors. do i just need to bend the two metal tabs and if so, which way up or down? Click to expand... Yes the metal tabs, you want to bent them down very lightly.
