J jmr3394 New Member Apr 14, 2010 #1 Ok so my bike's kill switch came with two wires. I hooked one up to the white wire but where do i put the other?
timboellner Member Apr 14, 2010 #2 Ground the other wire to the bikes frame. The wire usually has a ring connector soldered to it . The water bottle holder bolt is a good spot, but anywhere will do as long as it attaches to the frame.
2door Moderator Staff member Apr 14, 2010 #3 Here is a wiring diagram that has been posted many times before. Wire your bike to match and you'll be fine. Tom Attachments Electrical Diagram , Best.jpg 58.5 KB · Views: 437
Venice Motor Bikes Custom Builder / Dealer/Los Angeles Apr 14, 2010 #4 Don't connect it to the white wire! (It could someday short out the ignition) Use 2doors diagram!!
