Elevation is a consideration, but how about compression... Leave it to me to throw the thread a curve! I got my motor blown up and nixed my upper and lower gaskets! Torque is crazy! 2,000 miles on it!
Getting more air in a motor raises commpression too. RE bigger carb.
When I messed with the Morini motors this is an old quote to what I found.
My S6S with a larger 21mm phbg Dellorto may be running higher compression than stock with just the carburetor upgrade. Reason I say this is because I have peaked inside my S6S 9.4 hp. and my S6T 5.8 hp.
Their heads jugs pistons etc look identical. The only difference are their ignition, smaller carburetor and smaller reed valves. What I want to say is just by making these breath a little better raises the compression because a bigger breath of air is more air to compress. Like turbo charging a car.
The S6T 5.8 I have came with a very restrictive reed valve ''single wall 3 peddle medal '' and a very restrictive small bore carburetor. Verses a 4 peddle on two walls carbon fiber.
My S6C is getting a 21mm Del for sure!! The S6C must have a reworked head
S6C INTAKE Reed valve w/4 flaps in crankcase COMPRESSION RATIO 15,5 +/- 0,5 : 1
S6S INTAKE Reed valve w/4 flaps in crankcase COMPRESSION RATIO 14,5 +/- 0,5 : 1
S6T DISPLACEMENT 49,8 cc INTAKE Reed valve w/3 flaps in crankcase
COMPRESSION RATIO 12,5 +/- 0,5 : 1
What about this. I'm running an NT that's gassing well with a 60 jet. The venturi measures 13.74 mm.
I want to install my new Speed carb. It measures 14.78 mm. Should I start out with the same size 60, or should I go bigger at first to play it safe?
Go to a 61 eh? Dunno can't tell ya. In experimenting with tuning with my Morini tho..when I went from a 19mm to a 21mm I needed a bigger main jet my safty zone at wot was noticably too lean. This was acheived by simply transferring all the jetting parts right over from the 19mm PHBG. Both models of carbs were PHBG models all the jets etc crossed right over. The 21mm had a much less restrictive rear opening it breathed better and I felt better throttle responce immediately. .
I made real good freinds with the dellorto PHBG carbs. The needles, idlejet, main jet, atomizers can be totally changed around. It can be a pita learning this carby but man I think they are pretty versatile now. I am certain by now I can definitly match one up to where all stages of the throttle would be perfect! Its all in the jetting!
One my buddies here is running a 19mm carb on his H.T. forever here now and it is a great good runner. He thinks he could get a 21mm on his at sea level. Talked to him last night his and my consensus we both think this carby thing to go a little larger is by far way way more forgiving at sea level.
He ran a slightly longer intake than stock and the diameter of it matched the carb perfectly. Last with a tuned pipe..
I am absolutly sure a 18, 19mm will kick butt at sea level on a H.T..
