Denver Dave
Hi All,
I just came from all the threads in the "Vibration" sticky in this forum along with a search and several months of closely following all of the postings to this fantastic resource. I know my problem is not unique, however, the circumstances that led to it have me confused.
I have detailed the problem below but if you want the short of it skip to "The Short of It".
I have an old cruiser with a 50cc motor bolted to it. The motor is ported/polished, has upgraded hardware, made all new gaskets, and is well lubricated. I have 250 miles so far and am loving the experience! During break-in I was very careful to follow the proper procedures and ratios.
After about 100 miles I could feel the boost in power as the rings started to seat and felt comfortable going faster. My top speed on the 16:1 was 30.2 mph with very little vibration and I wasn't even close to hitting the top rpms the engine is capable of.
For the next gallon I went to 24:1 and changed out the spark plug to one of the popular NGKs. I had the same smooth experience and a top speed of 30.7 mph.
Here is where things started to get funny. Once I hit 190 miles I felt a fantastic boost in power and decided it was time to check all the nuts, bolts, and grease everywhere. I remounted the engine the same way I had before but made things more sturdy. I removed the stock chain tensioner and made a new one out of a razor scooter wheel.
The razor scooter wheel was too big for the bracket and would constantly get hung up on the tensioner mounting bolt forcing the chain to drag across it. Since this is my only mode of transportation to work (without having to pay an exorbitant amount for parking) I decided it would do for the time being even though it was causing the motor to bog down and my top speed was only 15 mph. That night I came up with a quick fix to keep the tensioner wheel spinning but the bogging down problem got worse and worse.
Mid-week I went and got everything I needed to use a skateboard wheel as the tensioner. Hooray! The engine ran fine again but once I hit 22 mph it sounded as if was was going to rattle itself apart. I rechecked my mounts, changed plugs, changed gas but by the end of the week the rattle was so bad at any speed I ended up just pedaling home from work.
Over the course of this past rainy three day weekend I proceeded to completely disassemble the engine - all the way down to the point of taking apart the lower and spilling the ball bearings. Since this is my commuter bike I don't want to go past that point until I am confident I have the proper spares on-hand to do so. Everything turned smoothly, no parts fell out, all the gears meshed, and the muffler wasn't clogged (although I cleaned it anyway). There was some carbon buildup on the piston but the plug looked fine so I am assuming it was from the 16:1 break-in mix.
I cleaned, lubed, and reassembled the engine (using new gaskets), every bolt on the bike now has a rubber washer, the engine mount is back to the way it was when I could go 30+ mph with some serious rubber washer action in between, and the engine STILL rattles when I hit 22 mph!?!?!
The Short of It
Engine ran fine at 30+ mph for the first 190 miles
Engine now rattles like it is going to explode above 22 mph
I took it apart
I put it back together
It still rattles above 22 mph
I can understand if this is a crank imbalance issue but why would it run fine for the first 190 miles and then start acting funny? Is there something that can shift in the crank balancing mechanism? Please help.
The Short of It
I took it apart
