I pulled apart my dax Gen4 this morning due to a bad leak on the case gasket. While I had it apart I planned on replacing all four of the case bearings. The small gear side case bearing was stuck on the crank shaft. I removed the bearing by squeezing the bearing in a vise until it broke and then grinding the inner race off with my cut off wheel. I've done this one other time very successfully only gouging the crank a tiny bit. This time I got carried away and I am using my dirty safety glasses as my excuse for grinding the crank so badly. My question is this crank useable? I cleaned up the burrs and the new bearing fits like a glove. Will this throw the balance of the crank way out of wack?
