sudjim
Good morning everyone,
I am helping a guy our with a bike he built that the motor chain keeps coming off the rear sprocket. I have built about 10-15 bikes so far and this one has got me puzzled. It is a beach cruiser. He took off the rear wheel and replaced it with another one without the coaster brake. It has a 5 speed cassette on it. I had to re-do the rag joint and get it trued up. It is well within spec (no noticeable wobble). Motor is mounted pretty well, and is not noticeably tilted or cocked, seems about centered between the bars.
But if you were to put a yard stick or straight edge on the motor sprocket when the rear wheel is properly on the bike, it seems to aim NOT at the 10T gear on the motor, but about 3 or 4 inches off the bike. I adjusted the rear wheel to where it seems to align with the motor, and the rear wheel almost rubs on the fork near the bike chain side. I got the bike to start and seemed to work, but then the pedaling side seems to jump teeth because that side is out of alignment. It never worked well and that situation lasted about 1/4 mile at most and then the chain jumped the motor sprocket again. Has anyone found a bike that just would not align? I've tried everything from bending the chain tensioner, adjusting the rear wheel, running no tensioner, switching chains. Should I try a new wheel or a new bike? Thanks mucho
