Haven't done this exact build myself, but a few general frame-prep points usually come up for a chromoly mountain frame. Check the frame for cracks or bent tubes before adding engine vibration, especially around the bottom bracket and rear dropouts. Make sure the rear wheel is true and the spokes are tight, since the extra load is hard on them. If you plan a dual-lever setup and a single speed, remove the shifters and cables cleanly and use a chain tensioner or chain line check so the drive chain doesn't rub. Fresh brake pads and a bleed or cable check before the first ride are cheap insurance.
