HS air filter upgrade
silverbear
The Boy Who Never Grew Up
I've been looking through different vendors offerings for a good looking 4 stroke HS air filter... not plastic,. but I haven't found anything yet. Anyone know of source?
Silverbear
Here are some pictures
So from affordable go karts you get the air filter adapter (Code: AGK100
Price: $14.00) and then the air filter to go with it from ebay at about $7.00. Looks really nice. What comes stock on the HS does not look really nice. What is the engine in your avatar?
SB
Ah, no shroud. Looks much nicer. I like it. Pretty amazing transformation just removing the shroud and giving it a nice looking air cleaner. Yes, is there a downside to removing the shroud? What is it for anyway?
SB
I had both the heat sheild & the shroud removed and figured I better put em back on. I would rather have a running bike than a non running bike that looks cool.I was afraid I would cook the valve.An I almost lost a finger with the pullstart shroud removed.
Didn't mean to enlarge the pictures that much!!
You might also want to contact the folks at SBP. I believe they are about to release there mount for using any of the 3 different Air Filters they sell for mounting to the Honda/HS motors.
ocscully
How did you almost lose a finger... from a cut or what?
SB
Ah, SBP! I'll do that. It looks like I'm going to have a real estate issue and might not be able to use any but the stock one, but I know SBP has a cool looking shorty that might fit. Thanks for the tip. I've always had good and quick service from Pablo and Ghosto... good guys and members of our forum.
SB
SB
When you remove the shroud the flywheel is in the open .I was looking at something while the bike was warming up and in went my finger.Nothing bad but enough to realize it was needed for saftey reasons.
MotoMagz
MotoMagz
That's disappointing cause it sure looked nice without it. I've got this thing about plastic on a motor. It just doesn't fit visually. At least the air filter is doable.
SB
What did you use to extend the breather tube(I think that's what you call it)? Is that flexible pipe electrical conduit? Looks good.
SB
