Ok, 2nd engine kit didn't pan out so well. But it seems its just the carb. It will die out after running a short while, then fuel dumps out of the overflow tube. I am only 1 1/2 turns out. I checked the float needle, does not seem to have any obstruction to it. All jets are clean. I am not good with carbs, so I just ordered a new one to be done with it. It also cuts out when first giving it throttle. Put the good carb on it to try, runs good but still cuts out. Valves have been adjusted and I even tried changing the magneto. Hmmm, must be me. gonna have to look closely at this one. I even unhooked the kill switch wiring to the magneto to make sure that wasn't it. Doesn't buck and jerk like the other two previous motors that were replaced, and the cutting out is not nearly as bad, but still annoying. At least I got one running like a champ. I should get new carb Saturday, then once I eliminate that concern I will tackle the cutting out at low throttle. Both motors still do not accel past 6800-6900 rpm. And I don't know if its because I am trying to find a problem, but it seems the valve lash is noisier than my other motors. They both came adjusted at .006/.007. I have reset both to .004/.006. I even tried .0035/.0045. I can hear the valves on these but don't know what's normal, I never paid attention to it before.
