heres the info i put in the other thread, i'll put it here so it will be easier to find for others needing it.
if your conector plugs are shatered like mine were you'll need to know the color code to match the wires to. after a late night of searching i found the info on a scooter forum.
from the motor the blue wire goes to the blue wire of the cdi. the brown wire goes to the red/black wire of the cdi. the yellow/green wire goes to the blue/white wire of the cdi and the black/white wire on the cdi is the kill switch wire.
there was some talk of the brown wire being a rev limiter and it was said to cut the brown wire for more rpm's, don't know how true the rev limit info is.
