WildAlaskan
this is great it belongs on the take a tip leave a tip thread
baird i like your brain lol. you know what works good for the end of a trottle cable the end in the slide
? take a red loop from a electrical kit strip the plastic off and solder it to end of cable and cut off the loop and file the end nice n smooth
Though I love DIY solutions and this is a year old topic do any of you know know where I can buy a machine and the ends to make my own cables like a throttle with a connector on each end?
I have a cable cutter and most everything only has the big end so I can handle that with ease and can get the cables cheap but it's that damn small end on on the carb cable that gets me.
I actually had good luck just using a cable end knobby but not quite the quality standrd or flexibility I need.
Actually I am looking for some sort of 'waffle iron' type machine that will heat and bond whatever size lead cable end I care to put on the cable where I want it, and of course those blank ends I'll need like the barrels for levers and the little throttle/choke ones.You can prolly make your own ferrules from some small dia. brass tubing from a hobbyshop.
Thanks!Here is a supplier with a huge variety of brass cable balls and other shapes (barrels, etc). You will need some specific information to order. Maybe call them, they might be familiar with motorized bicycle stuff.
http://www.flandersco.com/action.la...Operator=Contains&Type=End&Catagory=CablePart
