crmachineman
Hi everybody.
Upon cleaning of the rear hub bearings from my Worksman rear wheel. I noticed bearing damage. I found replacement balls on ebay, however one of the bearing cones is damaged. Does any one know if anyone sells individual parts for these hubs.
I have also bent two of the 3/8 x 24 axles on this wheel. This is unacceptable, and I will get some 4140 alloy bar and make a run of replacement axles. I'm not sure if they are using the best material for them. I will either use 4140 or go even higher to 4340 steel. I'll get them heat treated, like a grade 8 bolt would be done to.
-Fred
-Fred
