Good Day all
I am currently in the brainstorming process for building a nice riding Electric Bicycle.
This will be from scratch using of course many off the shelf parts, Gears, Bearings, etc.
However I do not wish to buy a mid drive kit. It will be more fun to build it.
I am a mechanical engineer so I can Handel the gearing and mechanics involved but I lack experience with the electrical side. Also I have full access to a CNC Machine shop so I can machine all my own parts.
I have tremendous experience with gas bikes but they aren't riding the roads here anymore. Time for electric.
Basic Concept thus far:
Ok this is gonna be a complex system but it will preform.
I'm thinking electric motor.
Custom machined mounting that includes containing the motor and the required gear reduction for said motor. Also included in this gearbox...we will call it transmission for now. The Motor is approximately 6 inches wide. This should fit nicely in the frame.
The transmission will also include a Variator which will allow for the motor to spin at a more consistent RPM and provide much more speed range without stressing the electrical system.
The variator in the transmission will connect to another variator mounted to a jackshaft and output to a chaindrive which runs a Spock on the rear wheel which is mounted on the disk brake mount.
#1 The Motor
http://www.hobbyking.com/hobbyking/...Max_100cc_Size_Brushless_Outrunner_Motor.html
Ya I don't need fast but I would like to travel 25 / 30 Mph without straining the motor. And I don't want trouble with hills.
So I need help with a few things here.
The Motor Rpm is rated 167KV.
The Motor Voltage is 45 volts approx.
So 167 x 45 = 7515 thousand RPM ???
Or is it 7515 rpm. I'm confused here.
I need to be able to calculate the motor Rpm under the load it would experience starting off with the bicycle say at 2 mph.
Also I need to figure the torque the motor can output from stall.
This I need to develop the geartrain.
My next big question is how to control the motor speed which seems possible using a servo tester and ESC.
Where the throttle turns the knob on the Servo Tester to control speed.
So I assume the Servo tester will be powered by a separate battery.
I believe the Servo tester outputs signal to the ESC controlling the output pulses to the motor.
In order to not fry the electronics the ESC needs to Handel up to 170 amps. The max of the motor. But the amp handling of the Servo tester need not be so high because only the ESC will have the power supply for the motor running through it.
Somebody please educate me here.
Some links explaining these topics would be great.
Electrical schematics even better.
#1 The Motor
