Does it die when you flip up the choke? If not, it's leaking air.
yea its in the right spot.I Just Read You Put On A New Carb Did You Instal The Cable Correctly If The Silver Disc Is Not In The Spring Return Will Not Work Properly And Could Leave The Throttle Open
Sounds like a lean condition, either from an air leak or carb needle too low.
