Hi i've been reading a lot of post on this forum so last night i checked my magneto with a meter its good read 326 ohms, tried a new ngk b6 spark plug,opened the head it was a lil dark from the oil so i scrapped it off and cleaned it good i tighten everything up right then i took apart the nt carb cleaned the filter and moved the lil pin on the needle to the very top notch on the needle put everything back together took unscrewed the bottom of the muffler and tested it without it,i got it to turn on fast went around the block around 4 times n it just died while i was giving it gas half way down the block i let it cool down for half hour and went out again to test it, won't start it sounds like its trying to go but just won't pick up speed and the pedaling got very hard to pedal it any help please am losing my mind also i have a stock cdi and a high performance 1 i bought both tested good so it can't be that
