help please.
docgonzo
I have a free spirit engine I am trying to put back together,but
i need a drive wheel this one I have is toast. Where to go to find one or does someone know or have one and alternitave will be fine just a bit of help would be awesome. Thanks
.xx.
a little more information about the motor would be good i tried to search for it but came up empty make a few more posts and leave a pic would be a great help.
I think the Tanaka bike bug might be the same?
you could try:
Link...... Bike Bug
Drive Wheel $28.00 The Drive Wheel is another item that has been improved on design. The rubber of the drive hub simply deteriorates with age and wear. We have put a neoprene high-speed roller skate wheel (62 mm) over the aluminum drive hub. It wears less, vibrates the engines less and bike goes slightly faster per revolution.
hi; you can bore out a rubber or synthetic skate board tire, usually free at a shop. get a couple and use a hole saw a bit smaller than the drive wheel, heat the tire in boiling water apply stickum to wheel and slide tire on. mitch
Thank you all so much for the ultra fast responses and all the input. I will keep you posted and my try the skate wheel trick. I have a col bike collection so I am sure I will be posting many pics and updates. Thanks again Darrin .fly
