Is your throttle working correctly? Is the slide (barrel) in the carb moving smoothly up and down? Is the cable binding? Have you tried the idle speed screw? In is faster, out is slower. Have you looked for air (vacuum) leaks other places like the carburetor to intake manifold and the manifold gasket where it attaches to the cylinder?I had a seal bad on a motor that was brand new and I had a friend who had a extra seal I think it was a china one so I used some grease around the outer part and the inner part.I pushed it in and it went pretty far and it's not flush is that to far in.I started it up and still revving higher than I like.I wonder if it is still leaking air don't see any fuel mixture coming out like before.I would like to know how to test it.I can spray something around it but it idles so high I'm kinda afraid to keep it running,but it's not running all way open I can rev it higher with throttle.So should I chance and let it run so I can spray something around it?
