HELP!!! 5.0hp Chain Drive Rack
derekfrelow
Ok so i have a big 5hp motor but it spins the wrong way meaning i would need to mount it with the gears on the left side it uses a #35 heavy duty chain. So i need to find a way to mount my drive gear on the left side
please help!!!
Re: HELP!!! 5.0hp Belt Drive Rack
Here are some photos showing a Timing Belt Pulley being set up on a Single Speed Disc Brake Hub. Is this the type of thing you are asking about?
ocscully
dammit i meant chain thanks any way
can an admin change the name of this tread please
they have some on the sites listed above but they may be for dirtbike or gocart axles.
or try these sites,but your #35 sprocket holes need to match bolts on adapter,you may need to drill holes on you sprocket to match.
ENGINE_KIT_PARTS_PAGE_2 spoke mount rag joint mounting
SPROCKET ADAPTER clam shell axle mount
