Greetings all! I'm new to the forum and motorized bicycling community as a whole having completed my first build just a few days ago. I chose a Skyhawk GT5 kit on a Schwinn Clairmont mainly for the vintage styling. I have "silently" received a great deal of help from this forum throughout the process (on and off for 4-5 days) and the ease of the Google search feature resulting in a nice, clean build that avoided many mistakes I may have otherwise made. Thanks for that!
This particular question comes after a few hours research here on topics similar to but not exactly addressing the problem I'm facing. By the way, the bike works pretty good otherwise and I've followed directions/informed suggestions/sound advice as closely as possible.
I find that the bike is a hard pedal when the motor is off and clutch disengaged, to the point that I've basically lost the bicycle part of it. In 1st and 2nd gear I can get up to speed to start the bike fine but it's put so much drag that I can't take a normal ride anymore, and that's coming from a reasonably fit individual. It feels similar to tightening the wheel bolts too much on a regular cycle to the point where it does not spin freely. I used to cruise on 4th gear without a motor but now even 1st feels like 5 or 6 on the same flat surfaces. I expected the extra weight and chain to feel like a gear or two up from normal, but this is crazy!
I double & triple checked the clutch for proper engage/disengage and it seems to be fine. At one point I adjusted the cable so the arm was absolutely maxed out in the disengage direction (had to leverage it to do so - there's so much tension) and it still pedaled heavy. I even loosened the flower nut over the clutch to increase its travel. Still starts and runs fine with no apparent slip but entirely too hard to pedal with the motor off. I'm getting no indication that the clutch is anything but fully disengaged. Alignment seems to be pretty good with no chain binding issues. I tried loosening the chain a bit via the tensioner but anything other than taught causes the chain to pop off on the outboard side of the 10t sprocket (think that's a tensioner issue - it sometimes acts as a derailleur when maladjsuted)
Any ideas out there? Assuming it is probably not the clutch at this point, I'm left to think that the 10t motor sprocket may be the culprit. I hear a lot of talk about the sprocket in "freewheel" mode with the clutch disengaged but this is hardly like that - it still takes considerable effort to turn it. Could there be anything other than the clutch causing this issue?
Having never ridden one of these before it's hard for me to say what's "normal", but by the descriptions out there this is not!
