Is 10 ft lbs enough? I was trying to check other threads and I'm reading between 12-17ft Lbs?when the head is properly tightened,does the raised center circle in head compress into gadget?
Well sanded head and jug installed, no leaks,presure tested at 120, now wet black oil filled plug.Re jetted all the way down from 68 to 62,still wet with oil. Died now and won't start, checked for spark,very weak.will change magneto this weekend.Are all magnetos the same(universal)?
