crazy mike
hi im mike ive solved the gt80 bog issues and then some shes doin 45mph easy first thing its a high compressin so needs lots of fule bend your float tab up just a little good air filter exspansion chamber idel out 3 air mixte er at two out seal up that little metel tab thtat covers the hollow spot for the choke they all vaqcume leak this is the reedvave clone run your gap at 34 if your high compression 22 if your stock needel clip in the center make sure all crank case and head bolts are cranked down 4once per gal premium yes the gt80 can scream this is my 4th build all with the gt80 reed valve clone.o yeah most important thing hd litening steals the show there is no compairison gotta have it makes the gt80 run like a raped ape
