When you say, "No Spark" that means the plug is not firing. Have you confirmed this? Remove the plug, connect it to the plug wire and ground the plug against the cylinder head fins. Walk the bike forward, clutch engaged and observe the plug electrode. Is there a spark present? If yes, then your problem is elsewhere. If no spark re-check your wiring connnections. If there is spark you have a fuel issue. Mixture correct? Fuel flow from tank to carburetor? Choke open? Check these things and get back to us if you find, or don't find the problem.I rode my bike for about half a mile, now it won't start.
Replaced the plugs, CDI, and just today the magneto, and gas. Still no spark. At least that's all I can figure out. It's getting gas, the clutch engages and disengages, it putt putt putts when I pedal, but dies immediately when I pull the clutch cable, or gradually as the chain goes slower. I've taken the muffler off to see if it's some plug up there, but no.
Any ideas?
