Fuel coming out of air cleaner.
Randiman
First I would like to thank every one who helped me with my previous questions. I have only one more. When I first put gas in the tank it ran out of the air cleaner. What would cause that?
Thanks again,
Randiman
Randiman,
Sounds like your float is stuck. Pull your carb off and the bowl and check your needle and seat. Something most likely got in there and is keeping the float from closing causing a overflow problem. If you are not running a fuel filter you may want to consider adding one.
also, check to make sure your plastic float isn't filling up with gas. if it has any gas in it, it's cracked somewhere and you'll need a new one.
So, Randiman...what did you find? It helps us and other members when a problem is solved and the reason is posted. That way we can pass on to others who might benefit from your success.
