Huffydavidson
STREETRACER/MANUFACTURER
Ross, the free nail polish its not funny I did two years ago on blue .it's cheap it's quick and it dries fast .I'll tell you what I did before I had a shift kit when I had a tensioner the keep it from moving on the frame I drilled a3 millimeter and put a stainless steel 3 millimeter allen bolt with a high locking nylon nut on and washer on both sides it was just as good as well into the frame and its cheap you drill through the tensioner through the frame through the frame through the back of the tensioner .and crank it down it won't roll into the spokes its a strong as a weld, costs about two bucks. And if you ever need someone to weld aluminum for you just check out your local tool rental yard ,their mechanic can Weld just about anything
