One in a million!!!!
I've been around here for a while, read almost every post and thought I'd seen about everything but this I've never seen.
The 'C' clip on the needle broke. That allowed the needle to drop into and block off the main jet. I've seen spring steel snap rings break before in other applications but I've never heard of one of our carb clips breaking. I've installed and moved quite a few over the years and never had one break and certainly not after it was installed and the engine has run for as long as this one has.
My main jets are small because I have to run lean here at this altitude. The needle is bigger after the taper than the orifice in the jet so when the needle dropped it completely plugged the jet. In fact it was stuck in the jet and I had to use a pair of small hemostats to pull it out.
This makes me wonder how many times it might have happened to guys who didn't quite understand how things in the carb work and just replaced the carburetor and went on their way. So I'm asking if anyone has ever seen a 'C' clip (some call them 'E' clips) break? I know they're easy to loose and I had one needle with the grooves not cut deep enough for a good fit, but just breaking in half is new to me.
