Im finally throwing in the towel on the 33Poulan. It just doesn't have enough for my needs. I tried getting the most out of it and in turn im pretty sure it needs to be rebuilt know. When im riding it flat spots or sputters under load, if i lean the H screw in it runs okay but will overheat and seize after about 10min. until it cools down. Im going to pick up a 40cc Poulan tomorrow for $60 bucks which hopefully will have a bit more power. Not sure if the 33Poulan could just have a vacuum leak but i already tightened all screws and still same problem. So until im able to get my Honda GX50 i'll have to try and make these work for now.
So if your thinking of picking up a 33cc Poulan then better to look around for a 40 or higher. I think Craftmas is the same as the Poulan also.
