Ratt_Bones
RBones
Explain how opening the muffler up so the engine can breathe betrer is a bad idea?
some of us here have several years experience not only with these engines but many others, and ill tell you one thing you left out or just dont know.
Carb tuning.......
If the carb is rejetted for the extra air flow through the engine a wide open exhaust wont hurt it in any way, as with any engine, extra air flow requires the fuel flow to be increase at the same time so that you dont have a lean run condition which causes the engine to run much higher temps which could potentially fry the engine, but if the engine gets a fuel flow increase that coincides with the added air flow what you get is a better running engine and more power.
The only life shortening effect that will be realized by doing this is that the rpm capability of the engone will increase and that and only that will have potential to shorten its life because now you can run it a little harder.
Not intending to be abrasive with this reply to what you said in your post but a good way to get some abrasive comment pointed your way on here is to speak as though one is an authority on something when the experienced know what you said is not the fact of the matter.
Ever been involve in Drag racing? They run open headers..... and the air/fuel mix is adjusted accordingly. ... I personally dont know of any engine that works any different.
Peace, map
It improves cylinder filling of the air/fuel mixture...if you lower back pressure the air/fuel charge does not fill the combustion chamber as well, but simply flows through, resulting in less power. It's like filling a bucket with water....if the bucket has a huge hole in it, it takes longer to fill it. Back pressure is like a wall in the exhaust port that the air/fuel mixture hits when entering the combustion chamber so it fills up more....resulting in more complete filling and more power on detonation. There are other important considerations regarding back pressure as well, but this is more important in these smaller engines
In drag racing, those engines are designed to go very fast in one direction for less than ten seconds, but yes I am familiar. I had owned and operated a hot rod shop for a long time before retiring from it.
It's ok, I didn't take it abrasive. I am sort of new to motorized bicycles, but not to engine tuning. I do know this though as far as my experience goes with these mufflers. I had a stock/unmodified muffler, my bike running at 43mph as it sat. I hit some railroad tracks and the muffler broke after the header. A buddy of mine lent me his muffler that he had been bragging about (same one) that he had done the same above mods to. After swapping them out, I can't get above 30mph. Although my bike sounds way better, it just lacks the proper back pressure. I'm not going to bother retuning the carb, but just wait and get a new pipe.
No worries about coming off as abrasive. I appreciate intelligent replies and feedback, rather than some one telling me that if it sounds better it must be better or something like that. LOL
