J jonsmoke New Member Jul 30, 2009 #1 Engine was working fine for awhile, stop using the bike for a couple of days, pedal and release the clutch and bike stops, and cant even pedal one bit. Tired to move the engine sprocket by hand with tool and cant even move it like i use to. Help???
J jonsmoke New Member Jul 30, 2009 #3 no its not the chain because when the clutch disengaed the chain moves freely.
Venice Motor Bikes Custom Builder / Dealer/Los Angeles Jul 30, 2009 #4 Take off the clutch cover & see if you see anything wrong?
J jonsmoke New Member Jul 30, 2009 #5 I did everything looks fine. Could it be the piston because it seems as if the piston is not even moving anymore?
Venice Motor Bikes Custom Builder / Dealer/Los Angeles Jul 30, 2009 #6 Ok... with the clutch lever "out"; roll the bike forward & backward... see if it (engine) will break free? Last edited: Jul 30, 2009
Venice Motor Bikes Custom Builder / Dealer/Los Angeles Jul 30, 2009 #8 Take the clutch apart, does the clutch shaft still spin? or is it in the crank/ piston? You'll need a gear puller tool that comes in some kits!
Venice Motor Bikes Custom Builder / Dealer/Los Angeles Jul 30, 2009 #9 You might have blown a main bearing...? Take the cover off the other side too... do you see any sign of it?
J jonsmoke New Member Jul 30, 2009 #10 no sign of damage, but by rocking piston is moving slightly but have to use all my froce to move the bike back and forward.
Venice Motor Bikes Custom Builder / Dealer/Los Angeles Jul 30, 2009 #11 I'm guessing it's a bearing... Anyone else???
Venice Motor Bikes Custom Builder / Dealer/Los Angeles Jul 30, 2009 #12 Take off the intake & exaust, look in the ports @ the rings... anything bad???
