Lemonade New Member Mar 6, 2018 9 0 1 43 Mar 13, 2018 #1 I know these motors idle but mine refuses... How can i fix this so i dont have to peddle start at every stop?
crassius Well-Known Member Sep 30, 2012 4,032 158 63 USA Mar 13, 2018 #2 did you try adjusting idle screw on left side of carb? Reactions: Lemonade
Chaz Well-Known Member Jun 3, 2012 1,004 72 48 Vancouver, British Columbia Mar 13, 2018 #4 Turn the idle screw in clockwise to raise the idle speed. Reactions: Lemonade
Lemonade New Member Mar 6, 2018 9 0 1 43 Mar 13, 2018 #5 Chaz said: Turn the idle screw in clockwise to raise the idle speed. Click to expand... Thanks will do it first thing in the morning... Do i turn it then start the bike and try to stop? If not i keep turning it until it continues to run even if the bike isnt moving? Do i have this right?
A Arturo Garza III New Member Jun 6, 2018 19 0 1 30 Jun 15, 2018 #7 You could buy a pull starter. For 15 $ dollars on eBay. Or an electric starter. How did you fix the problem with your motor?
