Engine spluttering when I hit 20mph...
Discussion in 'Motorized Bicycle Trouble Shooting' started by dimentio, Feb 3, 2013.
  1. Greg58
    Greg58 Well-Known Member
    May 1, 2011
    2,785
    41
    The air to fuel ratio entering the engine has too much gas in it, this is usually from too large of a main jet. A lot of the nt carbs run a little on the rich side. A ratio of about 14 to 1 is good, altitude can affect the mixture also.
    #21 Greg58, Feb 13, 2013
  2. BigBlue
    BigBlue New Member
    Nov 29, 2011
    781
    Too rich? Think of your carburetor as a primitive blender - it mixes the air and fuel together. Too rich means that you have too much fuel and not enough air. If ice was air and tequila was fuel, you have too much tequila and not enough ice in the blender. Your margarita would be too slushy! Not good!
    Hose? Probably a fuel grade hose or rubberized fuel line from an auto parts store.
    Good Luck,
    Chris
    AKA: BigBlue
  3. nightcruiser
    nightcruiser New Member
    Mar 25, 2011
    1,180
    When referring to the blend of air and fuel the term "too rich" means too much fuel, and "too lean" means too little fuel.
  4. dimentio
    dimentio New Member
    Jan 5, 2013
    71
    Hm... so i need to increase the amount of air entering the carb then right? I saw some pics online of a carb with the filter turned upside down with the intake holes shaved at an angle... might try that.
  5. Bikeguy Joe
    Jan 8, 2008
    11,529
    Move the c clip up one notch to lean it out, that's what it's there for.
  6. BigBlue
    BigBlue New Member
    Nov 29, 2011
    781
    You have to reduce the amount of fuel (tequila) or increase the amount of air (ice) to make that perfect frozen margarita!
    As bikeguy Joe stated move the C-clip one notch (add more ice). I would stay as stock possible before you add more variables to the mix. In other words, perfect the basic frozen margarita first before moving onto other fancy versions - no watermelon or peach frozen margaritas for you.
    Chris
    AKA: BigBlue
  7. Greg58
    May 1, 2011
    2,785
    41
    A sick bike parts air filter helped one of my bikes, it flows a lot more air than the stock filter.
  8. 2door
    2door Moderator
    Staff Member
    16,299
    24
    You could try adding a shot of tequila to your fuel mix but leave out the ice, lime juice and don't add salt. It might not run any better but your exhaust will smell great while you're riding :)
  9. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,335
    33
    on hoses, I like clear ones so I can see gas flowing
  10. Groove
    Groove New Member
    Nov 2, 2012
    245
    e-clip. That's what I'm talking about! Try moving it up man. One notch.
  11. Greg58
    May 1, 2011
    2,785
    41
    I use gates or dayco fuel line with a see through filter.
  12. dimentio
    dimentio New Member
    Jan 5, 2013
    71
    I can't seem to shake the problem. This motor i have is kinda beaten up. When I crashed my Schwinn riverside cruiser, i was able to salvage the motor from it. the motor has been thru a lot of trauma. rain, snow, i've even fallen once or twice on the genesis 29 i mounted it on. I even got swiped by a car a few weeks ago while i was parked. so i think its time for a new motor anyways. just got my RT carb in the mail yesterday. i just ordered a new motor this morning. Im just gonna wait for that and redo the bike. I also got a expansion voodoo chamber, i just need to take it to a shop to get it bent.
  13. nightcruiser
    Mar 25, 2011
    1,180
    Though you're motor may be beat up, didn't it run well before you changed to the new carb and intake? My guess is you need to TUNE the new carb, and you will probably have to tune the carb on the new motor too. If you want to experiment while you're waiting for your new stuff, either put your original carb back on the old motor and see if she runs better, and/or, move the float and jet (and air filter if it is different) over from the old carb to the new carb. My guess is the float setting is different on the new carb, move the float, move the setting. Or the jet could be not exactly the same size. My guess is it has more to do with the carb swap than the new intake or how beat your motor is. Good luck with your project...
  14. BigBlue
    BigBlue New Member
    Nov 29, 2011
    781
    In my opinion, your not going to get what your looking for if you don't know how to work on these engines and understand the principles of how an engine operates. Buying an engine and slapping on a bunch of parts without knowing how to tune your engine and conduct to basic diagnosis is asking for hours of frustration.
    Take the time to properly setup your engine and have an understanding of what you are doing before adding any modifications. Teach yourself.
    This forum has a wealth of information if you are willing to search for it and ask questions of other members and use the information that is given. Sometimes a problem can be solved with a quick question and a quick answer. Other times it requires testing of different components to see if the problem is resolved. Unfortunately we live in a society where everyone wants a quick answer and is not willing to take the time to teach themselves. We want some one else to solve their problems.
    Good Luck with your new engine.
    Chris
    AKA: BigBlue
  15. Groove
    Groove New Member
    Nov 2, 2012
    245
    I think Dimentio's on the right track. Everyone has their style when it comes to experimenting around with these funky engines.
  16. dimentio
    dimentio New Member
    Jan 5, 2013
    71
    I got my voodoo expansion chamber hooked up with the RT carb, my bike runs better but i still have low torque at low rpms. im going to try using rubber pads on the motor mounts and using one of the bigger jets provided with my RT carb.
  17. Bikeguy Joe
    Jan 8, 2008
    11,529
    Rubber mounting is a bad idea, it just allows the engine to flop around. It's not going to help running issues.
  18. Greg58
    May 1, 2011
    2,785
    41
    What you have is a small 2 stroke engine that does not develop a lot of torque at low rpms, a 4 stroke will have more low end torque. If you need low end you can change to a larger rear sprocket, but the top end speed will be slower. I just pedal at start or on grades.
  19. maniac57
    Oct 8, 2011
    4,486
    A two-stroke will have better power at any given state of tune. Twice as many power strokes.
    Four-strokes are only playing catch up from the start.
    Motocross had to give them twice the displacement to make them competitive with the ring-dingers.
  20. Greg58
    May 1, 2011
    2,785
    41
    I have owned 4 2 stroke dirt bikes and am aware of power for racing at high rpm, what Im saying is we are on a bicycle and sometimes you have to help these little engines out.
