So i tried the carb mod where you drill a hole to get air past the jet from the float bowl, and that made my engine lose power and only idle with the choke on, so i put my new spare carb on but the engine still doesn't run well under power and will stall after idling for a little while even if the throttle cable is adjusted so that its idling at a high rpm... im not sure if my gas mixture is right... could that make this happen? also i changed my sprocket to a 38 but it was running fine b4 i changed the carbs around.
"if it isn't broken and you mess with it long enough, it will be" really applies here
