frozenveinz
Heh, I went on a final ride before selling my 66cc bike, and what do you know, the engine died. I have about 600-700 miles on the engine. It never could revv past 6k. Running 87 with 32:1 Pennzoil. Today I ran it at 24:1 Pennzoil to get it lubed up.
When I left it was doing fine, running perfect.
About half hour later, at a stop light, it died at idle. I screwed in the idle switch some, started it up and it ran.
Next stoplight, it started to die again, but I revved it before it could. I noticed it took about 2x as long to return to idle as normal.
Drove off, and the clutch started to slip a bit. Screwed the clutch lever flower nut in some, didn't help. Turned around to go home, figured I'd fix it at home. Halfway there (I started back 4 miles away), it started to slip hardcore, then I pulled in the clutch, and it died promptly. Tried to start er up again after tightening the flower nut completely, but all I got was a bunch of clicking and scraping sounds from the motor.
Walked it the 2 miles home.
Got on motorbicycling.com, posted problem and story.
I think it wast the clutch slipping, but the crankshaft threads got stripped or some bearing jammed and the shaft got milled down.
