Engine chain not lining up
Discussion in 'Motorized Bicycle General Discussion' started by lolitsdaelan, May 29, 2010.
  1. lolitsdaelan
    lolitsdaelan New Member
    Apr 23, 2010
    60
    So I just got a SkyHawk engine, mounted it to the bike, and installed the sprocket. I quickly noticed that the chain does not line up with the sprocket at all, and even runs into the frame itself. How is this supposed to be mounted????
  2. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    any pics?......................
  3. lolitsdaelan
    Apr 23, 2010
    60
    I'm an idiot, got it figured out.
  4. freewheeling frank
    freewheeling frank New Member
    Mar 10, 2009
    440
    good fer u stay here
  5. Don Quixote
    Don Quixote New Member
    May 25, 2010
    I have the same problem. Enlighten this idiot. How did you fix the alignment?
  6. Starchalopakis
    Starchalopakis New Member
    May 13, 2010
    13
    As am I. The chain keeps slipping off the rear drive sprocket. Just an alignment issue I assume? How do I fix this?
    edit. and this is just with the clutch in pedaling, havent got her fired up yet.
  7. lolitsdaelan
    Apr 23, 2010
    60
    Well I haven't actually fired it up yet, so I'm hoping I'll be OK. I had apparently bent my fender a little when I was painting it, I just had to bend it back a little and it gave me the clearance I needed.
  8. bairdco
    Aug 18, 2009
    6,403
    50
    most times you'll have to cut the fender for clearance. even if you get it all set up and think it's gonna clear, as soon as you fire it up the chain jumps around and rubs on it.
    as far as sprocket to sprocket alignment, it's tricky, but it can be done.
    sometimes it's as simple as adding a washer or two between the hub and the frame on the engine side, and other times you might need to actually "spread" the frame.
    here's an article on that: Bicycle Frame Spacing
    i'm gonna copy and paste the last paragraph in that article, just for a CYA;
    "This job is one that isn't for everybody, but it's not rocket science either. Many shops are reluctant to undertake this sort of operation, either because of fear of liability or because they want to sell you new bike. Although it seems fairly alarming to deliberately bend your frame, it is really not that cataclismic an operation, and can be very worthwhile if it allows you to keep riding an old friend, with the advantages of a modern drivetrain."
    #8 bairdco, May 30, 2010
  9. Cabinfever1977
    Cabinfever1977 New Member
    Mar 23, 2009
    2,290
    Most cut a notch in the fender where the chain goes by.
    I left out one rubber and put the rear sprocket up against the spokes for a perfect alignment. The chain tensioner also helps the chain to go straight to the rear sprocket.
  10. Parbed
    Parbed New Member
    Apr 14, 2010
    6
    Yes in most cases I leave the one rubber disc out and go with direct mounting to the spokes/hub.
  11. lolitsdaelan
    Apr 23, 2010
    60
    Yeah I had to the take the second rubber isolator out and put the sprocket in backwards (chrome side out). Then with a little work on the tensioner, I managed to get it all to line up pretty well. Although now I have a whole new world of problems, but I'm gonna start a new catch all "daelan is an idiot and here are his questions thread" to keep them all in one place :p
